description HQPlayer Desktop 对于只有小喇叭的少年这只是一个可以播放flac和wav的音乐播放器而已,但是对于拥有整套硬件设备的少年就不同了,就算我不说是用来做什么的你们也自然知道。
Supported source formats:
▲ CDDA (Audio CD)
▲ FLAC
▲ DSDIFF (DFF, non-compressed)
▲ DSF
▲ RIFF (WAV, including DXD/RF64)
▲ AIFF
▲ RAW streams
Supported playlist formats:
▲ M3U / M3U8
▲ PLS
Features:
▲ Software upsampling / downsampling with selectable algorithm up to 32-bit 1.536 MHz or down to 16-bit 32 kHz PCM (25 options, most "apodizing")
▲ Delta-Sigma modulators for upsampling PCM/DSD content up to 49.152 MHz 1-bit SDM (24 oversampling options)
▲ Selectable dithering / noise shaping algorithm (7 options)
▲ Selectable convolution algorithm (FIR) for equalization, such as digital room correction (2 options), for PCM/DSD content
▲ Optional high-frequency expansion for the convolution engine
▲ Software-based digital volume control for PCM and SDM (DSD)
▲ Playback of DSF/DSDIFF files through any supported audio interface (PCM conversion and DSD rate conversion)
▲ Selectable algoritm and noise filters for DSF/DSDIFF PCM playback (7 / 6 options)
▲ Native/direct playback of DSF/DSDIFF files (ASIO DSD, DoP v1.1 with both 0x05/0xFA and 0x06/0xF9 markers)
▲ Playback of stereo, 2.1, 3.0, quadrophonic, 3.1, 5.0, 5.1 and 7.1 channel material
▲ Speaker configuration for multichannel playback (delay and level) for PCM and SDM (DSD)
▲ Matrix processing for routing, filtering and mixing channels with gain, for PCM/DSD content
▲ Bypasses operating system software mixer and sample rate conversion
▲ Support for professional ASIO drivers
▲ Network endpoint support with Signalyst Asynchronous Network Audio Adapters
▲ Support for ID3v2 tags on AIFF, DSF and WAV files (versions 2.2, 2.3 and 2.4)
▲ Smooth level limiter for clipped material
▲ "Dual wire" channel bonding support to reach 2x rates, PCM and DoP (DSD)
▲ 64/80-bit floating point processing
▲ Full support for multi-core processors
▲ Light weight desktop-GUI to lower graphics noise
▲ Touch-GUI for use with tablets or laptops with touch screen.
▲ DSP offload to GPU using NVIDIA CUDA
链接: https://pan.baidu.com/s/1Uug2h7tOBv6t3DI5tosv1Q 提取码: sx12
